what size inverter will i need to run a basic cheap microwave■■?
You would need to check the power input of the appliance, output might be say 750w but the input will be a fair bit higher (typically around 1200 watts).
check this out it mite guide you
You should double whatever the cooking power of the microwave is so if it’s 700w use at the very least 1400w inverter but if it was me I would use a 2000w inverter and run in from the batteries/Anderson plug.
sammy:
^^^this,also I run the engine everytime I use mine,I have a 1500w inverter with a 700w microwave not had any problems whatsoever.
Watt?
stagedriver:
Watt?
Don’t you have an ohm to go to?
