Hi All,
How many gallons of petrol can you carry in a small 7.5 truck before you need ADR ?
I got told it was 2L, as I rerused to carry 18 x 25l tubs !
Vosa told me I need a ADR !
Thank you for your help
Think itās diesel.dave who can help you on this one?
rob.jonesno1:
Hi All,
Hi rob.jonesno1,
If petrol is packaged in 25L packages, then the maximum you can carry without an ADR licence is 13 of them.
The ADR āfreebieā limit for petrol is 333L, so 13 X 25L = 325, which is just nicely inside the 333L limit, but VOSA were correct to say that you would have needed an ADR licence if youād carried 18 X 25L packages.
The above is a āper vehicleā exemption, so the size of the vehicle isnāt relevant and applies equally to a transit van, a 7.5t or even an artic.
The notion of carrying dangerous goods in small packages is a different and quite separate ADR exemption known as the Limited Quantity (LQ) exemption.
To qualify for this exemption, the petrol would have to be packaged in receptacles of no more than 1L AND be contained (possibly with some other similar receptacles) within another packaging, such as a cardboard box which itself doesnāt exceed 30Kg. If that is complied with, then there is no other limit and so a full load could then be carried without an ADR licence.
Daveās āStrange but trueāā¦
Both exemptions can be used on the same vehicle at the same time.
dieseldave:
Daft question probably - does that also apply to a combination such as W&D or Van + trailer ?
ROG:
dieseldave:
The above is a āper vehicleā exemption, so the size of the vehicle isnāt relevant and applies equally to a transit van, a 7.5t or even an artic.Daft question probably - does that also apply to a combination such as W&D or Van + trailer ?
Yes ROG, that also applies to a van and trailer or a W&D, since they are āvehicles.ā
You wouldnāt get a āfreebieā of 333L for each of both parts of a W&D!!
dieseldave:
I said it was a daft question
dieseldave:
rob.jonesno1:
Hi All,
Thank you for your helpHi rob.jonesno1,
Hi Mate,
where can I get this info on headed paper so I can print it off as it is VERY important !
Thank you
Rob.
Hi Dave,
Thank you for your help and info, but where can I get this printed off on headed paper ?
As I Need it urgent !
Thanks
Rob.
rob.jonesno1:
Hi Dave,Thank you for your help and info, but where can I get this printed off on headed paper ?
Thanks
Rob.
Just mention dieseldaves name to whoever is giving you grief!
rob.jonesno1:
Thanks
Rob.
Hi Rob,
You could do as merc0447 said.
Iām afraid that itās not really feasible to print this off on headed paper because it comes from several differnt parts of three law books, so please let me ask you who needs to know this information.
Their exact name isnāt necessaryā¦
- Is it the sender of the goods?
- Is it a freight forwarder?
- Is it the owner of the vehicle?
The three people/organisations listed above usually need to employ a properly qualifed DGSA and so they shouldnāt really be challenging you on this. (ADR 2011 1.8.3.1 and 1.8.3.3)
The relevant law is The Carriage of Dangerous Goods and Use of Transportable Pressure Equipment Regulations 2009 (as amended.) This is a set of Regulations made under The Health and Safety at Work etc Act 1974, headed by the Queens Royal Crest, which hopefully the person asking the question will accept as headed notepaper.
CDG 2009 (as amended) Reg.5 requires that the relevant parts of ADR are obeyed (in the circumstances you described) for a UK national job involving the carriage of dangerous goods.
ADR 2011 8.2.1 requires drivers to hold an ADR certificate if they carry dangerous goods.
However, ADR 2011 1.1.3.6 gives an exemption from 8.2.1 (and a number of other sections of ADR) provided that the vehicle is carrying packaged dangerous goods in a total quantity of less than the relevant ADR transport Category limit for the dangerous goods in question.
We already know that the petrol was packaged in amounts of 25L, which leaves out ALL possible discussions of Limited Quantities (LQs.)
According to ADR 2011 1.1.3.6.3, the relevant āper vehicleā limit for petrol is 333L because ADR 3.2.1 says that petrol is in ADR transport Category 2.
IMHO, the VOSA officer was correct in his interpretation of ADR 1.1.3.6.3 becuase 18 X 25L IS enough to require an ADR licence because 18 X 25L = 450L, which exceeds the 333L exemption limit.
I am also correct to say that you can carry 13 X 25L packages (= 325L) of petrol without an ADR licence because 325L is LESS than the 333L exemption limit in ADR 1.1.3.6.3
I hope this helps.
Hi Dave,
It is the owner of the Truck and Company with 13 motor bikes in and 18 x 25L of Petrol in,
So a lot of Fuel .
Thank You
Rob.
rob.jonesno1:
Hi Dave,
So a lot of Fuel .Thank You
Rob.
Hi Rob,
Thanks for the extra info.
The motorbikes arenāt relevant, so whatever fuel is in their tanks doesnāt count towards the 333L limit.
The fuel in the motorbike tanks is carried by use of yet another (different) exemption.
In ADR, the owner of the truck is called āthe carrier.ā
It is the carrierās responsibility to know whether ADR applies to a job or not, but it certainly isnāt the driverās job unless the driver also owns the truck.
In normal circumstances, ADR 1.8.3.1 requires that a carrier has to be able to consult a properly qualified DGSA, so Iām afraid to say that asking a driver without a DGSA qualification to perform this function is not only ridiculous, but illegal.
For your bossā info, the responsibility of knowing whether ADR applies to a job used to be a driverās responsibility, but this ended on 09/05/2004.
The UK law on DGSAs has been in place since 01/01/2000.
Please donāt worry about this mate, because what you say you did was completely legal, and you were spot-on to have refused to carry 18 X 25L of petrol. Itās as simple as that.
Good grief, Dave, that takes me back to my last ADR course!
Is it worth pointing out that, although it is the haulierās/shipperās responsibility to determine whether a consignment is covered by Dangerous Goods legislation, if the driver KNEW that it should have been covered by the DG regs, he is also comitting an āAiding and Abettingā offence?
Retired Old ā ā ā ā :
Hi R O F,
The problem for the enforcement authorities here is that they couldnāt prove that the driver knew, since it isnāt the driverās responsibility to know.
All a driver needs to say is āthe sender / my boss said Iām not subject to ADR.ā
Itās also worth pointing out that if a sender says there is some kind of exemption applicable, then it would be helpful in avoiding enforcement delays if itās written on the driverās delivery documentation (Transport Document,) something like āLoad not exceeding the exemption limit in ADR 1.1.3.6.3,ā or similar.
In the normal course of events, a employed driver has to obey his bossā instructions or face a disciplinary, so IMHO itās a good thing that the courts realise this otherwise thereād be the scenario you describe.
Absolutely, Dave.
One of our customers was a real stickler for the correct paperwork and if anything was deemed to be āa bit borderlineā would indeed add the statement suggested by you, that the goods were NOT subject to the legislation. Certainly helped a few of our drivers.
On the other hand, we had our fair share of the āchancersā among the customer base: those who thought it was O.K. to send a nominally āemptyā acid IBC back to the supplier with a gallon of the dodgy stuff slopping around in it. Or loading an IBC with D.G.s when it was ten years out of itās date, battered to hell with a rusty cage around the plastic. Oh, and donāt forget the, āHavenāt YOU got labels, Driver?ā.
Thereās much to say for being retired!
A Big Thank you to Dave and all !!
Thank you
Rob.
