Users of TomTom satnavs (and many other devices) will be aware that the micro-USB connectors used to charge them are quite fragile. The problem is not simply caused by repeated plugging/unplugging of the connector, but by sideways forces on the cable “fretting” at the connector and the printed circuit board that carries it. Typical symptoms will be that charging becomes erratic and eventually stops altogether. Many users won’t even realise there is a problem until it’s too late as a small amount of movement/vibration is often enough to re-establish connection, with the device battery keeping it going in the meantime. A significant issue here though is that Lithium Ion batteries don’t like being repeatedly connected/disconnected and before long the battery will fail. The 90 degree connector used on some TomTom devices is particularly prone to this as it is effectively designed to be used in a LHD vehicle, with the cable exiting to the right.
Repairing the micro-USB connector on the TomTom charging cradle is difficult for us mere mortals, so normally a new cradle is called for (at £30 or so a pop!). Other phones/devices that don’t have a similar cradle arrangement may require the whole thing be replaced…
SO, as I was faced with replacing the cradle for a third time (first one FOC from TomTom, others paid for by me…) I decided to look at the problem and see what could be done to alleviate the issue. My solution, while not exactly elegant, seems to be holding up well. I purchased some Sugru “mouldable glue” from Amazon (£6 for a pack of three sachets) and set about forming a solid support for the cable/connector to prevent the “wobbling” of the connection, left it 24 hours to cure and -Voila! No more intermittent charging. I’m sure the same principle could be applied to most other micro- and mini-USB charger connectors.
Here’s a piccie of my effort (I did say it wasn’t elegant!)
