All evidence based on the fuel gauge test, possibly leading to disciplinary action against driver.
Errr how can it be the Drivers fault? I accept hypothetically speaking, that if he had a fuel card and passed a fuel stop then that’s being a bit daft and evidence for being given a rollocking.
If you have a regular vehicle, and assuming it doesn’t have one of those anti siphon fittings, its always a good idea to shine a torch in the tank and see where the fuel level sits in comparison to the pick up pipe when the level gets below 1/4, that way you know just how low you can push it if needs be.
I’ve driven a truck that run out of fuel show well above empty on the gauge. Next time I drove it the gauge worked properly again. That was with single tank.
I’ve also had problems with twin tank, drawing from the side without the sender unit, until it empty. That was breather problems.
limeyphil:
Always carry a stick and a torch, you can’t trust technology.
Ok, but as Dave says, what if the pick up pipe is too short?
On quite a few Dafs, They had a gauze at the bottom of the pickup pipe, It usually corroded over time and fell off, This resulted in there being 2-3" of fuel left in the bottom, The easiest solution was to lift the pickup pipe and sender out and stick a bit of rubber hose on the end.
I usually carried the stick for the red diesel tank on the fridge, They never show the right level. But still handy when you’re given a new to you lorry, What the gauge says and what’s in there are usually a mile apart.
I had this years ago in a DAF LF 7.5t, was a few miles from the fuel station (left work with a full tank) and the bloody thing just conked out, wasn’t even on the red, did a video to show the boss that the gauge moved when I turned ignition on etc, but he wasn’t bothered, he just said “daf ■■■■”
Got paid overtime for walking to the fuel station and back too, and got refunded the cost of the gerry can and fuel
The DAF LF 7.5t puddle hopper I get to drive can be a nightmare. you can`t fill the plastic tank to the top & even if you tipped it on its side, it probably only holds 60/70ltrs max, which makes running 600km trips a pain to plan as you need to factor in where the BP stops are. Running from Doncaster to North Wales (Rhyl, Caernarfon, Criccieth & Portmerion) usually means having to find fuel either at the services near flint on the way out or grit my teeth & hope the fumes get me to Pwlheli)
DAF lf gauges are crap! I’m on my third lf now no two have ever given similar readings. In fact, sometimes the same truck can’t even decide how much is in.
Last one I had I fueled one day when the light came on, and got something like 72.18 litres in (on the verge of overflowing) following week I filled it up at the last Shell for miles, and despite the gauge showing quarter of a tank in, got something like 99.13 lts in (100 litre tank)
PaulNowak:
One tip some of the lads at our place haven’t tapped onto. Turn the nozzle 180 degrees skywards. You’ll get a good 20 litres plus after the nozzle originally clicks shut.
