pv83:
newmercman:
The flip axle is a typically American method of doing things, as in it makes little sense! It basically converts a tandem into a triaxle, so does add versatility and I’m sure that it should be flipped when running off the interstate when empty on some roads in some states as technically a 48’ trailer is as long as you can go, there’s no way to flip it manually without a crane/forklift and therefore mine stays on the floor.Patrick is correct about the shims to get it sitting level and load equalization is done through the load sensing system of the trailer itself, it can be a lot of messing about, but that is this job in a nutshell, no two states or provinces have the same rules and they seem to change with the weather too, each load requires a permit and three trucks can load the same thing, in the same place for the same destination and each get a different route to take.
A sat nav is a complete waste of time, as the routing you get conflicts with it and you’re constantly being told to make a U turn. My last trip was 1900 miles give or take according to Garmin, in reality it was 2600 miles on the odometer. All because of the routing specified in my permits.
Finally, the reflective red and white D sign is used in Ontario to allow night time running, but then only on dual carriageways and when the weather is clear, if you need the wipers on, you have to get off the road asap. The do’s and don’ts on this job are like the complete set of the Encyclopedia Brittanica!
Sent from my SM-G930W8 using Tapatalk
The “messing about” and “that’s the job in a nutshell” comments are very familiar NMM [emoji38] Still, that’s part of the fun isn’t it, I wouldn’t do owt else if I’m honest… not that I’m qualified to do owt else as some on here might say…
Cheers for the info mate, seems it’s a bit like in Europe, every country has got their own legislations, sometimes it’s even different from one county to another (Germany).
That’s right Patrick, overcoming all the challenges in the oversize world is extremely rewarding. I’m new to the game, but I’ve found my happy place.
