Can’t speak for the “Guru” but I’ll try to answer anyway
ROG:
Been trying to work out if this is legal or not as I was presented with this question…
I won’t go into a long story but just present the facts - who said good
No-one said “good” … we said “thank [zb] for that”
ROG:
Regular job (A) in warehouse Mon to Fri 2pm to 10pm and every other Saturday from 8am to 4pm
Extra temp job (B) for different employer driving C1 from 6am to noon Mon to Fri under EU regs
He will fill in a seperate tacho card for every shift done in job (A) with name,date, start & finish time.
The weekly rest is ok - 38 off then 56 off (repeating)
Job (A) is under the normal WTD
Job (B) is under RT(WTD)R
Do the daily rest requirements need to be complied with ?
Yes on any day when driving to EU regulations
ROG:
Does the 48 hour average need to be complied with ?
I would think so as the warehouse work will be counted as “other work” but it’s not really relevant anyway as the driving regulations take priority over the WTD and the shifts described don’t comply with the tachograph regulations (daily rest requirements).
ROG:
I do not know how this works when there are TWO seperate jobs under THREE different sets of regs.
Forget the WTD just think about the driving and tachograph regulations
Basically what you’re saying is that he will be working from 06:00 to 22:00 Monday to Friday with a 2 hour rest period between 12:00 and 14:00.
Read it that way ROG and I’m sure you’ll see that it can’t be done legally as there will only be an 8 hour daily rest period between 22:00 and 06:00.
It makes not the slightest difference that the work will be done for different employers, and the WTD is the last thing this person will need to worry about.
He’ll be working to EU regulations in the morning so the warehouse work in the afternoons will be classed as other work and the daily rest requirements will need to be complied with.
There seems little point in discussing the charts or the Saturday work as the shift pattern you describe can’t be legally done anyway.
Whether or not it could be done safely on a regular basis is another question
