Green Party policy creates massive driver shortage!
Blunder Man:
If you watch and listen to the woman who runs the Greens, Natalie Bennet she is patently stark staring mad, ignore her.
Watching that Aussie woman spout on tele you can be forgiven for thinking that “Mad cow disease” is still with us,she wants to ■■■■ off back to Aus but I suppose even they won’t let the crazy ■■■■ back in once they got rid in the first place and it’s only the gay vote in Brighton that put that other peculiar bird Caroline Lucas in as an MP last time so with a bit of luck she’ll get blown out this time around.However,it’s nearly as bad up our end as that ■■■■ Farron is our MP and it looks like the ■■■■ will make it in again this time.Cheers Bewick.
Olog Hai:
Olog Hai:
The Greens are going to have as much influence on how the country is run after May as I am.
Unfortunately the ‘Greens’ and the rest of their socialist and Con allies already have more than enough influence on how the country is run.IE a regime dedicated to the global warmist religion and which applies socialist principles.Because the CBI sees an advantage in it.No surprise the softening up exercise to create support for the latest round of mass African cheap labour immigration now being well under way.
Having read that I think I’d much prefer the Greens having an influence on the country’s future direction than you.
If you are serious in what you say (and I believe that you are) then you are nuts. Absolutely, 100% crazy.
So it would be fair to assume that you aren’t exactly opposed to the global warmist and pro immigration agenda.Which,with the exception of UKIP,is a cross party consensus from Greens to Cons.
The result being health and economic issues caused by inflated fuel costs and people drowning trying to get here based on the ( correct ) idea that if they can make it they can most likely stay. :unamused:
As I said, you are nuts.
My tare is 19700. An average diameter 4.9metre log weighs approx 300 kilo.
Yard to wood approx 90 minutes. Lift one log on. Wood to Mill approx 90 minutes. Lift one log off. Grand.
Expect a shortage of milled timber a month or so after they are voted in then.
Think they should stick to eating lentils.
Olog Hai:
Bearing in mind that the socialist cause is well known for locking up its opponents on the basis of re indoctrination to ‘their’ way of thinking. :unamused: :laughing:
They are a stupid party and not worth a word
