Gelling with a 4 over 4 gearbox
Actually ow hard would it be to include videos from the various road users in the theory test?
Not too hard but it would be like the HPT - no real feeling and perception for the situations.
ROG:
MADBAZ:
I drove a four over four for the first time a few days ago and apart from a couple of muddly moments :blush: I was fine, When I forgot which gear I was in, a quick feel of the position of switch was all I needed. :bulb: Preselecting the range before going into neutral is a tip (somewhere else on this forum) well worth knowing :bulb: . For most situations you know if your gonna have to ‘range up/down’ so preselelecting before changing gear puts less strain on the grey matter and the truck…
There is a lot to be said for the old ways of learning - passing the test in a straight box and then, a little further on in a career, getting a larger rigid with a range change and/or splitter and being left alone to ‘sort it out’.
A few pointers from a fellow driver and a short practice drive usually got it sorted IMO.
Thats okay learning the old way, as long as you’ve grasped the principles of why there’s a high/low range there in the first place, hence the suggestion of using a weighted bicycle, this does several things;
  1. shows the trainee what high/low is all about, setting off using the small chainring is a lot easier than using a large one, and easily selected by a little switch on the handle bars.
  2. It can be done in a quiet area without any stress on the instructor or the vehicle or other road users.
  3. The trainee will learn rather quickly (or run for the hills) if they’re having to put a lot of physical effort into it.
  4. If bike is suitably heavy, then getting to grips with tail lift operation (if fitted) is a bonus.
It goes without saying, this is for those who get into a complete fluster/can’t fathom rangers out.
I was quite lucky being able to drive coaches as a lad, then cycling and then messing with Landrovers, 4 forward gears, High/Low box and Fairey Overdrive giving 16 forward combos and 4 reverse, and they were used, especially when some dumb arse driver dropped the back wheels of a 53 seater into the pit.
