gearbox daf xf
limeyphil:
i had one of those new fangled autos once.
as soon as i sat on the bunk to read the paper, or open a bottle of wine, the bloody thing went all over the road.
auto???my arse. :smiley:
That’s because you forgot to turn on the cruise control :slight_smile:
empty unit, set off in 5 low, race cars from lights and beat em 5 low 7 low 8 high ,what clutch?
limeyphil:
newmerman.
you must run at some seriously heavy weights if you have to set off in 1st in DAF.
and the example i gave, was just that. an example.
it’s very difficult to tell someone what gears to use because it all depends on the weight of the load, and the terrain.
in a scania, i’d always have to use 2nd, 3rd, and 4th. but a DAF has always been comfortable starting from 3rd to 4th, or 2nd to 4th.
The bloke that showed me was Daf’s top demonstrator in Holland, he showed me a load of charts showing clutch temperatures and the increase that occured with evry higher starting gear, heat contributes to wear. The first gear start off is only literaaly to get moving, just lift the clutch pedal, let the electronics take care of the throttle, as soon as you’re moving you grab second and give it some right boot.
The bloke from Renault said exactly the same thing, but then when Renault switched from the B18 to the ZF box, they recommended using 2nd low to pull away :open_mouth:
mezzzz1211:
:grimacing: :grimacing: :grimacing:
i have never ever done this in my “yooth”
mezzzz1211:
A 13spd or 18spd Fuller will, allegedly, take off like a rocket in high range crawler, it is also rumoured that you can do burn outs in this gear with all the diffs locked up on an MAN 8 wheeler if the roads are slightly damp :open_mouth:
i t is “apparently” possible to drift on damp roundabouts ,but being a sensible upstanding proffessional driver i can niether confirm or deny this :imp:
limeyphil:
3rd low split, low range,
4th low split, low range,
5th low split, high range,
6th low split, high range,
6th high split, high range,
7th low split, high range,
7th high split, high range,
8th low split, high range,
8th high split, high range,
bmw
brake lights
think he might be talking about the old jeremy clarkson video where hes driving the volvo do keep up boys :unamused:
newmercman:
mezzzz1211:
what’s a high range crawler? :smiley:
scotttruck:
Hello, work have just order a daf xf 95 manual and just wondering how to change gear its a 16 speed splitter box i think before i go out in it for the first time?
Should you really be driving a lorry■■?
limeyphil:
newmercman:
mezzzz1211:
It is the crawler gear, but in high range, it’s a little higher than 4th and lower than 5th, but the beauty of it when used for a fast getaway is that you’re already in high range, so slotting into 5th takes no time at all as you don’t have to wait for the range change, allegedly :laughing:
neepdocker:
scotttruck:
he had the balls to ask an honest question, of course he should :unamused:
to many muppets on here these days, who forgot what it was like to be green at the job, and were born with the knowledge on all things trucking related. the minute someone in this game claims to know it all, is the minute you know they’re full of s h i t!!!
to many people easily forget what its like to be the new kid on the block. i’ve being doing it no for 20 years, but never roped and sheeted a load in my life, so this would be the first place i’d come for advice. fortunately i know there are some real good people on here that would tell me what i need to know, as opposed to the recent influx of pretend “trucking gods” that really havn’t got a ■■■■■■ clue :unamused: all to easy to spout a load of old bollox, actually doing it, is something very different.
