Garmin Dezl SatNav Issue
I have a Garmin Dezl 760LM, and for the most part it is spot on. I recently began using the Smartlink app through my phone to get a little help with the endless parade of road closures. This too works quite well with one glaring and very annoying exception. The SatNav is aware of road closures, but does not update the route to avoid them. It basically tells you the road ahead is close and then tells you to keep right on going. Has anyone else run into this problem? If so, any idea if it can be fixed?
I don’t have the smartlink turned on, but when I see a road ahead closed if I press the right most menu on the bottom of the map, you tap ‘change route’ then press ‘detour’. It works brilliantly in this aspect, especially on motorways when you hear there’s been an accident ahead [emoji106]
Sent from my ONEPLUS A5000 using Tapatalk
I don’t have smartlink so
I follow the diversion route when
The road ahead is closed
