Evening any of you chaps tramp on fuel ?
before they went under hardstaffs in Nottingham used to run CNG or LNG whichever it was between Glasgow and Bristol I believe.
was that adr pet regs war ?
am sorry I don’t know as not done ADR but I would assume lng comes under the same rules?
diesel dave will be the man with the answer.
bjd:
Theres a BWOC driver on here that does/used to do it.
Pimpdaddy:
bjd:
Evening any of you chaps tramp on fuel ?Theres a BWOC driver on here that does/used to do it.
Hello there:)
Judging from your others topics OP pet regs and tramping etc
The 12v cig is used as night heater isolation. You still have 24v hella socket. If required buy a splitter and 24v to 12v dropper. I have everything plugged it. Fridge, sat nav, chargers (phone ipad etc) and my TV. ALL battery powered and igntion sources will have ti be handed into terminal. Everything else is gravy. As for the truck pet regs dont really effect you as a driver or tramper. Just got to manage with one 24v hella socket and no sun roof as its sealed:) If you are not in the terminal and tramping you can carry what you like (NOT GAS COOKER) as long as stuff gets handed in terminal. I know you’ll be on for Turners. Some companies (days only) have different policies on what they let you take in the cab. But like I said, carry anything you need for a week out. The trucks and trailers have services inspections and MOT but also safe loading passes. Basically the pet reg test. As long as you have a in date SLP its all good:)
