There’s no way that it can be putting in less fuel at 100% accelerator input as opposed to less.IE the most ‘economical way’ regards fuel consumption can only be the slowest.
Unless they’ve invented a way to get more acceleration from less power and therefore less fuel and for fuelling to reduce as accelerator input increases.
I’m not sure it’s as simple as that, once you put a gearbox into the question.
For example, from a standing start, using gentle accelerator input, it might take you, say, 1 km to get up to limiter speed. Now, if you were to floor it on the mid-range gears, is it going to use more or less fuel to cover the same distance? The obvious answer would be “more”, but by flooring it, you might get up to limiter speed in, say, 500 m, and then you’re cruising the second 500 m in top gear. Provided you’re not running the engine at ridiculously low revs, the most fuel-efficient gear is always going to be the highest one available, so IMHO, it’s perfectly possible that it could be more fuel-efficient to accelerate harder (within the green band) in the middle gears so that you’re spending less time in the inefficient gears, and getting into the more efficient gears quicker.
As for whether cruise control gives you better fuel economy or not, IMHO the answer is “in most cases, yes”.
Certainly there are situations where a human driver can do better than cruise control, by anticipating the future - for example, when driving over the Alps, I used to ease off before the summit of a hill and let the speed come down to, say, 70 kph, in the knowledge that going down the other side the truck would be accelerated back up to 90 kph for free by gravity. Of course, I’d only do this if there were nothing behind me
. In this case, the fuel spent keeping the truck going at 90 kph going up the hill is going straight into the brakes on the downhill section, so there’s no point in maintaining full speed right up to the summit.
However, in flat cruising situations I think that cruise control will probably do a better job than most drivers because it will tend to react much quicker to the truck speeding up and slowing down, and make much more gradual changes than a human.
Of course, most drivers effectively spend the vast majority of their time on “cruise control” anyway, as that’s what basically happens when the truck is sitting on the limiter.
