I know some of you lads use a lot of electrical devices when parked up. If your battery is flat in the morning here is how to start her up !
f,m, gently !!! just imagine what we would have been watching if the rope had locked on the guys hands … whack,whack,whack,whack.
Always park up on a hill, facing downhill.
nodding donkey:
Sage advice.if your motor hasn’t got an air leak, and also if it has one of them stick thingys coming up out of the floor!
the maoster:
nodding donkey:
Always park up on a hill, facing downhill.Sage advice.if your motor hasn’t got an air leak, and also if it has one of them stick thingys coming up out of the floor!
Old skool, all the way…
nodding donkey:
Did it in reverse once in an 18 tonner. Was kind of parallel parked, as well, so had to steer out a bit, with no power steering too.
Good job it worked otherwise I would have looked a right ■■■ blocking a busy junction, had to let it roll a good bit to get enough momentum to dare lift the clutch, as there wasn’t enough road for a second go.
