As there has been some recent debate here in the forums whether or not 60 tonne “superlorries” should be allowed in UK I thought to (once again ) post pictures of such lorries operating here in Finland
Here’s on which I think would be most usual sight over there. My though is that this kind of setup could be used over there to do trunking at night and deliveries/collections during the day when caravan trailer is left to the yard (or then some rigid could load caravan during the day).
Another example of similar type of possibility is to use rigid for deliveries during the day with or without (mid-axle) trailer and couple dolly behind the rigid for doing trunk runs during the night. Here’s an example of a such a lorry probably heading to the port to get a loaded semi-trailer from there. Not the best example of the scenario I described, but replace that fixed superstructure with a swap body and it gives quite a good versatility.
Here’s a better example of a such lorry with a swap body and semi-trailer coupled to the dolly. Only downside with this one is that semi has automatically raising first axle which made it more than a bit awkward. Luckily I didn’t have to drive with this more than an about hour one Sunday after I swapped lorries with another driver to get a better one back
Here’s an example of similar weigth vehicle which can’t be split more than into two parts A starndard A-frame trailer, not one made from dolly and semi-trailers. I’d guess that over there this kind would be quite small minority as this setup doesn’t have that much versatility than other examples which probably is a big minus if these “superlorries” have only restricted routes.
Sorry for reposting this picture, but this is best photo I’ve got from B-double. This kind of setup have been allowed here only for couple years and you mostly see these hauling containers. I guess this would also be quite popular over there as both trailers could be used for deliveries during the day and only one lorry would be needed for doing trunk run during the night.
Just to point out that these are used even outside Finland here’s a Danish example near port of Turku probably waiting for ferry to Sweden.
Next are coming few pictures about what I did about a week ago. Regrettably this ain’t 60 tonne “superlorry” as six axles permit only 53 tonnes.
I’ve collected load from a farm in Central Finland at Friday week ago and looks like winter already passed by I should have realized that it makes yard kind a muddy and should have taken rubber boots with me…
At Monday I managed even to spot some snow when uncoupling trailer. I also spotted one small and windy water-on-ice -covered uphill track nearby but didn’t have guts to take a picture from it as I would’ve been in a ditch after that
Few roller cages collected from a farm. This one’s an easy place, wide road and plenty of space to turn around.
Here’s my nice and almost shiny lorry just waiting that I began unloading cages.
