As it says on the tin. Finally getting going with things in motion and then this setback.
Some of the questions are really hard and with all of the stuff I’ve read and mock tests I’ve done you just aren’t prepared for how specific some questions are.
Do you have an iPhone /iPad? There is a fab app for practising, and I just got to the point where I had memorised the answers. Not trying to depress you but I got 100% after studying with the app, so maybe worth a shot?
Best of luck for next time, you should be fine as you can’t really go backwards with theory!
Oh it gets worse. One of the questions I remember flagging was how stopping distances were extended in icy conditions. I’d selected 10x the distance. Then reviewed the flagged questions and for some reason changed it to 20x. The correct answer was 10x
th2013:
What app? I have one but still never saw some of the questions i got.
Despite having the most up to date app (Android) and web based tuition (supplied by my trainer) I still had 6 questions in my actual theory test that were not in either of my programs knowledge bases. But as said above you just need to sit there and practice I found quickly that the ones you dont know you get wrong, then the next time the same question comes up you remember and get in correct…
Right driver on the iPad worked a treat for me , just work your way through all the lgv questions and u won’t go far wrong , they cover I 'd say 2/3 rds of what you’ll get tested on
