Franglais:
These pipes (filled with air) are displacing water. Remember Archimedes?
It takes energy to do so.
Or are you arguing that they are vessels so heavy that they sink under their weight?
Then how much energy will be required to raise this weight when they have no buoyancy? Much more than that provided by air (not at 1400psi, by the way since you have described a rigid tube or pipe) pushed out as water enters from the base.
Displacement and bouyancy is dependent on the weight v volume/bore/wall thickness of the pipe.
Negative buoyancy pipes are routinely made.
So we sink an air filled pipe to 1 km, preferably 2km, then open the bottom of it to the sea.Why isnât it then being filled by the incoming water at 1,400 or 2,800 psi blowing the air that it contained out of the top at that same pressure ?.
Why canât that amount of force provide enough surplus power to power the winches needed to lift the pipe ( sections ) out of the water.
Bonus points if a system of counterweighting can be provided like a lift also bearing in mind that ânegative bouyancyâ isnât the same thing as zero bouyancy.A submarine doesnât generally sink like a rock to Davy Jonesâ locker when its ballast tanks are opened.
Also bearing in mind that we are probably 75% there anyway with the technology used for deep sea oil drilling.
An air filled pipe is lowered into the sea. When a valve on the bottom is opened, air is expelled through the top, by the water entering. (That is what I understand you to say?)
At 1km you are correct the water pressure is about 1,400psi (mixing our units so lets stick with metric units please? (Pedants point: I am not stating SI)
Now if we open a valve on the bottom all the air in the pipe is not instantly transformed into about 100atm. (100kg/cm.sq.)
It is a dynamic situation as air is being expelled and driving the turbine or whatever you have on top of the pipe.
But to show what we do have, lets seal the top of the pipe? The air inside will be compressed as the water entering through the bottom rises. We can examine this to see how much energy we have, can`t we?
Imagine (keeping numbers simple) a 1,000m of pipe with a cross section of 1m squared. As the water rises up our sealed column of air, compressing what is trapped in the top, it`s pressure increases. (Remember I am doing very rough back of envelope aprrox here) You end up with 1 cubic metre of air at 100atm.
To recharge the cylinder, after you have used the compressed air, you raise it out of the water, allowing the water to drain out of the bottom?
Now, you said the air filled pipe will sink under it`s weight? Since it is displacing 1,0000m x 1m of water it must weigh (Archimedes) 1,000 tons.
You need to get sufficient energy from that 1cubic metre of air to raise 1,000 tons through 1,000 metres, just to break even.
But you don`t even need to worry about all that detail, just look at where the energy comes from.
The energy is produced by water displacing/compressing gas.
A thousand tons of water gives you energy, and you shift a thousand tons to tube to harvest it.
Ed type sizes
