Juddian:
biggriffin:
Well I’ve had one now for, 4+ years in an FH4, find it’s good, few annoying things, Like Auto-realese not available, Manual only, Just push it in, The not pulling out sufficient to engage properly, yup done that a few times, as for stopping at lights, or a hill when you just want a slight hold, Well just pull the aux-brake lever towards you, that engages the brakes, Better than the poxy Hill start button, I do like the automatic on when Ign is switched off, You can gently pull Hbrake lever gently to apply light pressure…It’s new technology,
As you can tell i rarely if ever drive Volvos now, by auxilliary brake lever do you mean the 3 stage engine brake stalk, or is there a proper secondary brake lever (sort of modern day dead man) fitted which applies brakes independantly?
I too don’t use the hill start button, i’m in control ta very much, last time i used one was on a rental Stralis, the bloody gearbox took so long working out what gear it needed and once found re-applied power that the poxy hill start timed out and the lorry started rolling backwards, rubbish.
Don’t like the sound of Bald Bloke’s experience, might as well have a real parking brake that once it slots in place its there, end of, few times i’ve driven anything wioth an EPB i’m poncing about looking for a bloody light to tell me the brake’s on, don’t want that crap i want to hear a specific hiss of air (Clayton Dewandre Foden Style, no missing that) and feel and see a proper lever lock in place.
The 3 stage auxiliary lever, just applies trailer brakes, at speeds less than 5kmh.
