Hi all? Just a quick question put my card in this morning usual questions etc then it came up with “Driving without card” straight after pressed the ok button and it went away, everything has recorded on my card fine but has anyone any ideas?
gm:
when does your card expire ?
known to every one they mes up within a few days of expiry
regards
Steve
This wasn’t a card problem, he said he got all the usual questions which he wouldn’t have done if his card was malfunctioning.
It happened prior to his card being inserted and the warning simply hadn’t been cleared. If there is a warning on the screen such as driving without card or break required, and you don’t notice it before inserting the card, the normal card insertion routine will run through and then the warning will reappear and require okaying, it won’t be marked against your data.
