i think you would find that the tare weight of a globetrotter 6x2 would be nearer 8 1/2 tonne, so you would still not be allowed to drive it
The ones which load at our place are 8760kg, and that’s without the driver. Our own FM Globetrotters are 7780kg, so I can’t ever see an FH getting below 7500 without major surgery.
Harry Monk:
In a word, yes, you can drive a tractor unit with a Class C licence.
Any trailer over 750 kgs for LGV is +E
A rigid LGV does not have a trailer so is a C
An artic unit on it’s own does not have a trailer (+E) so is therefore a C
Thanks again guys, will look into getting a class C. Very helpful.
Not after a bus or coach, but take your point I could drive a 12m coach on a car licence (with some people on board), which is a lot bigger than a tractor unit.
Y111RDF:
Cheers
It just goes to show the logic of our driver licensing system.
i thought you could drive a unit on a car licence as long as it had no 5th wheel or any type of coupling
look at that lorry chis eubank drives i belive he doesnt have a hgv licence
chris_g:
I think you will find that he has a C1 licence as he passed his car test before 1997.
The 5th wheel or any other type of coupling has aboslutely no bearing on the licence needed to drive it under the current licensing catagory regulations
DVLA licensing criteria -
Firstly it is done by weight - if no GVW then actual weight = B, C1, C
Secondly it is done by the total number of seats = B, D1, D
The second takes preference to the first.
For all catagories of C & D vehicles - any trailer over 750 kgs requires a +E on the licence
chris_g:
Indeed he does, he’s got a C , he trained with Hills at Plumpton, same place I did. Think he has the C&E as well as he was going to do that with Hills but couldn’t get a test to suit him so he went somewhere near Southampton (or so Hills told me!)
IIRC, Chris Eubank does hold a C+E licence, he did a Nescafe advert where he was pulling a trailer with his own unit and he stopped to pick up a hitch hiker who thought he was Frank Bruno
On the V5 the taxation class in section 4 changes from HGV to Private HGV. You would then pay £165 pa for your years road tax.
Insurance wise, I insure mine with the NFU. They have always given me a very competetive rate. The policy has unlimited mileage and £1,000,000 public liability and buildings insurance included. These are the norm if your showing a vehicle.
With your truck, you still need an annual full HGV MOT test carried out at any VOSA HGV testing station. You can pull a trailer but the trailer goods won’t be insured and I don’t think the trailer will either, but not certain. As long as the vehicle is not used in conjunction with any business or hire or reward away you go. Also the plating certificate is still plated as the gross vehicle weight. Mine is plated at 38,000kgs. Remember don’t overload it.
You will also be tacho exempt, but your tacho will still need a calibration certificate as per normal. Your speed limiter will need to be working if one is fitted depending on vericle age. As far as VOSA are concerned when it goes for test it’s the same as any other HGV.
Hope some of this helps. Sorry if I’ve repeated what some of the other posters have written.
F10 Globetrotter:
Thanks for that, someone else recommended NFU and also Footman James.
There is no intention of pulling a trailer, so may look at downplating it to avoid needing a trailer for the test, if this is possible.
Have you got any breakdown cover, someone suggested the RHA scheme?
Is there any pics of your unit on the forum? Would be interested to see them.
