Coffeeholic:
tachograph:
Being able to enter start and finish times, or any other activity manually would in no way deter from a timer keeping an accurate recordAnd you can indeed do that with the timer as it currently stands. As I said, all the entries you make are manual, you decide when to switch it to rest at the end of a shift and switch it from rest at the start. You press the various buttons during your shift to switch the device to and from other work, break and POA. As every entry you make is in fact a manual entry it already does what you want it to do.
OK, I mean it would useful to be able to enter start and finish times manually at a time to suit, without having to press the button at the correct time, I know you can make manual entries by pushing the appropriate button at the correct time.
Coffeeholic:
I think giving the option to go back and change things or to later them retrospectively would be a mistake. Previous incarnations of the Hours Guard have been looked on favourably by the likes of VOSA, with drivers reporting of being stopped and when the official notices they use an Hours Guard they dig less deeply than they might, and one of the reasons they did like the device was the fact you cannot make corrections or alter the info in anyway. If you could go back and alter things then I don’t think it could be sold as a way to accurately record your activities.
I can only speak for myself, but it doesn’t really bother me how VOSA regard a timer that I use, I have no problem with VOSA checking the times on my charts/card.
For me at least a timer is a tool to help keep track of work activities and times, I fail to see how if I push a button at a certain time or enter that same time retrospectively it changes the accuracy of the resulting record, weather or not VOSA or anyone else thinks that what shows on my timer is accurate is irrelevant as far as I’m concerned, as I said I see a timer as being a tool to aid the driver not VOSA, and therefore would prefer to have a tool (timer) that conveniences me rather than VOSA or anyone else.
