scotslad:
most gangs who use this method use nitrous oxide (laughing gas)
Exposure to Nitrous Oxide causes light-headedness, an involuntary mouth movement which resembles laughter, and euphoria (You used to be able to buy it from Timothy White’s when I was a curious teenager) but does not cause unconsciousness unless administered in enormous quantities.
Fentanyl is a “knockout gas” but there would have been dozens of deaths reported if criminal gangs were using Fentanyl.
That is not a list of chemicals which will knock you out, it is a list of chemicals which won’t knock you out.
But there will always be someone who says you could squirt a can of Easy-Start up a night heater’s exhaust pipe because a significant proportion of lorry drivers talk out of their backsides.
Harry Monk:
Yes but some ■■■■■■■ will try it and kill someone if you see what I’m getting at, but like you or someone else said more than likely bs that this ever happened.
scotslad:
its not the gas that makes you unconcious and sick its the lack of oxygen a small compressed bottle of nitrous oxide released into a enclosed space could be enough to kill a person due to the lack of oxygen
