delboytwo:
Coffeeholic:
delboytwo:
with regard the wtd he will have to recored itIf the other work is non transport related he won’t, which is what I said.
OK then your telling me that’s is OK for me to drive 5 days a week which i work under the EU reg and RTD and then i can go and do 2 days flipping burgers and the hours i work at the burger bar does not count for wtd
I can’t tell you it’s OK because it isn’t. You would not be having a weekly rest period as required for the EU Driver’s Hours Regulations. If you did as you outline above you would be contravening the hours regulations but the burgeer flipping would have no impact on the WTD as it applies to mobile workers, those hours would not count toward the 60 hour maximum or 48 hour average.
delboytwo:
but you have said that you need to show what you did on other days not driving
Where did I say that? I said you need to show you have worked but you don’t need to show what you did on each of those days in detail. Name, date, start and finish times are all that is required and that is for the tacho regs not the WTD.
in a week were he also drives under EU rules then he will need a record for each of those non driving days. The record needs be no more than a disc with his name, the date, start and finish times on it, it doesn’t need to be a detailed account.
delboytwo:
and there for if you did wouldn’t you have shown that you had no rest under EU regs if stopped by vosa
In a week in which you drive under EU rules you will have to take a weekly rest period. So work 5 days in an office, fill out a chart for each of those days as detailed above, drive on the 6th day and get stopped by VOSA = no problem. Drive on the 6th and 7th day and get stopped by VOSA = big problem, no weekly rest. You could likely only work one day every 2 weeks as a driver depending on start finish times for both the main job and the driving shift
delboytwo:
What if a worker agrees to work longer hours?
An individual worker may agree to work more than 48 hours a week. If so, he or she should sign an opt-out agreement, which they can cancel at any time. The employer and worker can agree how much notice is needed to cancel the agreement, which can be up to three months. In the absence of an agreed notice period, the worker needs to give a minimum of seven days’ notice of cancellation.
Employers cannot force a worker to sign an opt-out. Any opt-out must be agreed to. Workers cannot be fairly dismissed or subjected to detriment for refusing to sign an opt-out.
Employers must keep a record of who has agreed to work longer hours.
Which is perfect for the part time driver. He has agreed to opt out of the WTD in his main job so the hours he works driving do not impact that and his office hours do not count toward the WTD for mobile workers so he will never come close to teh 48 hour average for that.
delboytwo:
so can i ask you this as a driver we are subject to the RTD and as we can not opt out of it, and this is my main job any other work would come under the WTD which we are still required to follow, unless you have opted out in the second job
If you worked 5 days a week as a driver and did the odd day, one every 2 weeks, at another job you would opt out of the WTD so your driving hours wouldn’t count for it and the odd day would not count toward the RTD so you are fine. By only doing one day every couple of weeks you should be okay regarding weekly rest for the tacho regs.
