Right this is a really silly question and i am 99% sure I know the answer. Can you drive a vehicle fitted with a digital tachograph (card type) with out a digi card?
Also the tacho unit is displaying driven without card, I am going to be driving it either tomorrow or Monday will it come up with anything on my card and if it does would I have to do a print out and write on it when I started driving the vehicle to cover my arse.
You can only drive without a card if it is lost, stolen or faulty. In these instances you must comply with the regulations of reporting it within 7 days, and then you are covered for 15 days. Obviously doing the print-outs before and after your shift. You cannot drive without a card if you haven’t been issued with one, or if you simply forgot it!
Obviously you have a card, otherwise you wouldn’t be concerned about the “driving without card” showing on it! So if you think that you may have forgotten it and drove the vehicle, you would be in trouble, however, if you thought that you’d lost it, and then found it again, that may be more acceptable
Hi mate sorry didn’t explain it very well, yeah I have a card but other people dont and have been driving it which I didnt know until today I persumed they had a card to be honest.
This will be the first time I have used my card and the first time I will of driven the vehicle.
Big Brummie Macca:
grumpybum ahs answered that for you.
Big Brummie Macca:
The “Driven without card” will not show on your driver card, just press “OK” and it will go away
Big Brummie Macca:
The information that the vehicle has been driven without a card will not be shown on your card but it will of cause remain on the VU for at least 12 months, it’s not unusual for the “driven without card” to show, for instance when fitters fetch vehicles I’ve never seen them use a card and you end up with the tachograph informing you that the vehicle has been “Driven without card”.
The problem will be if the vehicle has been driven for any significant distance and VOSA download from the VU for any reason your employer could have some awkward questions to answer.
But it’s their problem not yours so I wouldn’t worry about it
Don’t worry about the driven without card, clear it by pressing ok, it will happen anytime where other drivers or fitters move the truck even a yard. Don’t even worry about VOSA as your card will be ok, just the VU will remember. If you were going on the continent, they may ask questions.
Dont forget to use manual entry if you need to before taking the truck over and do not forget to put the start country in at the beginning. UK in this case
Big Brummie Macca:
How does the manual entry work and when would you use it. Is it for adding extra work when you have been driving a van or something like that?
That would be one use for it. I use it every day at the start of the shift to account for the time between me arriving at work and getting to the unit. At the start of each shift I also use it to add a bit onto the previous shift to account for the time between leaving the unit and leaving work.
Big Brummie Macca:
How do you turn it onto break and other work as well, dumb questions I know but I have never used one before.
Same as you do with a ‘normal’ tachograph, with the mode switch, each time you press it it cycles onto the next mode - Other Work - Break/Rest - POA. It is marked with a 1 and is next to the eject button so be a little careful.
Big Brummie Macca:
Basically you do a manual entry for any time when you’re cards not in the tachograph and you’re working, such as after you take the card out at the end of the shift when you may still have paperwork to do, or at the start of a shift when you’re working before putting the card in.
Big Brummie Macca:
Big Brummie Macca:
Big Brummie Macca:
On a more serious note in order to answer your question we need to know starting/finishing times, break times and how much POA you’ve booked, we will require you to give this information for the past 6 months so we can work out which week your last weekly rest belonged to.
It will be easiest for the Guru’s to answer your question if you give the information in the following format.
I realise this has nothing to do with your question but … hey! I’m having fun
Now we move onto this.
Ah, good father,
Thou seest, the heavens, as troubled with man’s act,
Threaten his bloody stage: by the clock, 'tis day,
And yet dark night strangles the travelling lamp:
Is’t night’s predominance, or the day’s shame,
That darkness does the face of earth entomb,
When living light should kiss it?
I saw this in another thread and thought it could be relevant
