A couple of times this past week I have done some night runs (e.g. starting 21:00 05/06/13, finishing 09:00 06/06/13). When I printout my shift from the tacho (Siemens VDO) the printout only gives details for the day my shift ended on i.e 00:00 to 09:00 06/06/13.
How do I set the unit to printout my entire shift?
Solent:
A couple of times this past week I have done some night runs (e.g. starting 21:00 05/06/13, finishing 09:00 06/06/13). When I printout my shift from the tacho (Siemens VDO) the printout only gives details for the day my shift ended on i.e 00:00 to 09:00 06/06/13. How do I set the unit to printout my entire shift?
Solent:
Just in case you didn’t know it’s not a legal requirement to do a printout.
I assume you’re doing printouts before taking the card out, and that’s why you’re getting a printout from midnight to the end of your shift.
At the end of the shift withdraw your driver card, as the tachograph goes through the card withdrawal procedure you will be asked if you want a printout, use the arrow keys to select yes, you will then be asked if it’s a 24 hour printout you want again select yes.
This should give you a printout of the shift start to finish.
Any other method of doing a 24 hour printout will give you a printout from midnight to midnight, as you’ve already found out
If you have worked across 2 days, then when you choose to print out, the date should be flashing, use the arrow buttons to choose which day you wish to print, you then get 2 prints for that shift.
EDIT I think you have to choose to print before you eject to get the choice of which days to print. Fairly sure this was how I did last time I had to.
Done a night shift for another client still using Seimens VDO and this head unit works as expected, giving me a print out for both days.
I’m now thinking the tacho that isn’t printing out the full shift must be faulty or something, I will bring it up with the transport office.
alamcculloch:
My card is stuck in a Stonebridge unit ,any ideas as to how to eject it?
Try unplugging and plugging the head back in. If this doesn’t work there’s a small plastic section on top of the head casing which you snap away to access a small lever which pops the drawer open.
bald bloke: Just in case you didn’t know it’s not a legal requirement to do a printout.
OT from the ops question but i had a few words with my TM today ,he said it was a legal requirement to do a daily printout(he said he had phoned VOSA to clarify) i said it wasn’t .I have read this both on this forum and VOSAs site (i think it was there) .My understanding is that a daily printout is needed only if your card is faulty,lost or stolen or you are swapping between analogue and digital ,is this correct or have the rules changed.
There is no legal requirement to do printouts unless you need to do a manual entry on one for circumstances like you’ve described.
I doubt that a VOSA person would have told your TM that daily printouts were required for normal every day use, it’s more likely that he misunderstood what he was told.
Thanks ,that confirmed what i thought and mis understanding what people say is a very annoying trait of our TM/bus driver
