Digi Tacho help needed
shep532:
tachograph:
I’ll tell you what the OP is a classic example of though, someone who’s having to learn something new to him and has the intelligence to come here and ask about things he’s not sure about, and do so safe in the knowledge that if wrong information is given there’s enough people here so he knows that someone will correct it.
Can’t say that about the DCPC can you :wink:
How does he know which advice is correct? Usually on most threads there will be 4 or 5 (or more) variations on a theme. :wink: :smiley:
I think that’s a fair point Shep.
I also take your point about a belt-and-braces approach, which I think is good general advice in most situations in life. My point here is that, in an unpredictably variable situation, a belt-and-braces approach leaves you covered if something goes wrong.
IMHO, the point at issue isn’t variable.
chappy261 said this, which IMHO is incorrect:
chappy261:
any mistake you do like forgetting to change your tacho to rest, you must take 2 printouts and write on the back of both that a mistake was made and note the time of the rest period should have been. you keep one for 28 days and give the other to your transport manager for their records.
chappy261’s wording suggests to me that he strongly believes what he wrote, which if you read the links I provided above prove that this isn’t correct. I’ve even suggested where I think he might have got confused, because sometimes two printouts are actually required.
It’s not for any of us to assume the reason for chappy261’s belief, indeed it could be for a number of perfectly possible reasons, such as:
  • He was misinformed on a DCPC drivers hours course
  • He was correctly informed, but misunderstood the info
  • After the passage of some time, he didn’t remember the info correctly
  • He takes ‘company policy’ and gives it out as “you must…”
  • Somebody is simply gilding the lily
  • Other…
:bulb: Given chappy261s Dad’s qualifications, I’m still interested to see his comments.
shep532:
tachograph:
You can’t resist the temptation to get a plug in for your DCPC moneymaking course can you :laughing:
No. :smiley:
When you teach drivers hours for DCPC, how do you make the point that I’ve quoted from chappy261 when Reg.561/2006 clearly doesn’t require a printout in that situation and even VOSA only “strongly recommends” a (single) printout?
IMHO, it’s important to teach people where the goalposts actually are, then explain what might be considered as good practice, or a way of exceeding minimum requirement. I think that properly explained differentiation is key to a genuinely good understanding of something that’s a matter of law.
shep532:
tachograph:
Well yes there can sometimes be differing opinions but I don’t necessarily see that as a bad thing, usually most people will agree in the end especially where the relevant parts of the regulations are used to bring any doubt to an end.
In fact this thread is a good example of debate bringing out the correct answer to a question, where a poster made an incorrect reply then when it was pointed out as being incorrect he tried to change his reply by saying “BTW, i explained the procedure for when a mistake is made not when the digi was taken out!” which clearly had nothing to do with the original question and was most likely nothing more than an excuse for the original incorrect reply.
I would say that when it comes to questions about the regulations 99.99% of the time people end up agreeing about which is the correct answer, in fact there have been numerous occasions when people who have given incorrect replies to a question (myself included) have ended up saying they’ve changed their minds and have learned something new.
When it comes to learning in a way that will be remembered there’s nothing like open debate, which is why the DCPC compulsory training attendance will never be a good way to raise the skill level of the professional driver :wink:
dieseldave:
chappy261:
dieseldave:
I have read what chappy261 posted and cannot see why it isn’t correct.
He hasn’t said that in the situation described by the OP he should take 2 print outs etc etc. He has said that ‘in general’ if you make a mistake do 2 print outs, write on them etc etc and I believe that to be sound advice. His post starts “Any mistake you do like forgetting to change your tacho to rest”. I read that to mean that if you make a mistake - do 2 print outs, write the story on the back of both, hand one in and carry one for 28 days.
The one word in chappy261’s post that seems to have caused the multiple posts is the word MUST, as in “you must take 2 print outs”. I would imagine he used the word ‘must’ because he believes it is a ‘must’ to do this to cover all eventualities.
An example “Have you been to see you Mum and Dad for Christmas Pete?”. “No I haven’t”. “Oh but you must!” “Really - I MUST? is it law?? or do you just think I MUST■■?”. Some people use the word must in strange places.
How do I cover things like this during DCPC? it all depends how the particular course goes. One of the good aspects of DCPC is that you can easily have 20 drivers from varying backgrounds and with varying knowledge and experience all in one room. We are then able to promote sharing experiences, thoughts and knowledge. By discussing everyones views and thoughts we can come down to a difinitive answer. I often take somebody’s view and use it as an example often ending up quoting the regs from the book to prove/show why this view is right, wrong or just another way of looking at it. You cannot beat real life experiences being presented to the class.
In a way that 20 people in the room with a common interest is a ‘little trucknet forum’ where everyone in the room can ‘post’ (speak) but people may think twice before opening their mouths and saying something they would readily type whilst hiding behind a username. therefore it may remain a little more polite :wink:
So - in the example of this particular thread. lets say the OP was on the same course as chappy261. OP relays his question and I turn to the class for possible answers. Chappy261 says “Take two print outs etc etc”. I would then pose this to the whole class and take views on it. Discuss the rights and wrongs etc. I am sure this would be along the lines of “Why would you need 2 print outs?” "Well you aren’t wrong but, the rules don’t say I need to do that and I could have done this or this or that … " Chappy261 would be able to put his reasoning across - and that is exactly what this forum does not allow people to do. I always try to include people in the classroom. Some don’t want to be included, some enjoy it but it certainly benefits the group.
If nobody in the group feels talkative and doesn’t want to join in - then it helps if the trainer has a few experiences to draw on (i.e. ex-driver)
didn’t chappy261’s first post need a reply such as “Well yes you could do that, but I don’t believe the law says you have to. The law actually says blah blah blah and I would suggest the OP did this, this and that rather than 2 print outs etc”.
Anyway - the final answer was correct. the OP got his advice and learnt from it.
So - has this post been another attempt to promote my over-priced, not needed and never correct DCPC services? I do hope so :smiley:
tachograph:
A-ha!! I hadn’t seen this post before I posted my previous reply.
I think you are wrong with this statement. A well run DCPC course can definitly promote and encourage open debate. I love it when it does. Beats me doing all the talking :smiley: it isn’t just about some guy standing at the front quoting chapter and verse.
With some training it will always be a guy stood at the front quoting things - that’s because it is new to the audience and they are there to learn something new. Periodic training on the other hand is for drivers that will already have knowledge and experience and it is about bring that out for all to share. Yes at time it is “sucking eggs” for some, but not for the person sat next to them.
I think it is great when I see a driver helping another driver to ‘get it’ yet an hour ago they didn’t even know each other, which is why a good course will include ‘group activities’, ‘games’ etc
A course last Saturday brought up the inevitable “You can’t record a break whilst sitting in the waiting room at Tesco” debate. This was started by one driver and three more joined in to agree with him. This got all 14 drivers involved in a ‘controlled’ debate and at the end of it everyone ended up singing from the same hymn sheet including the original ‘objector’ who had ‘personally been fined £75’ whilst recording a break at Tesco :wink: In the end he agreed that he COULD record a break whilst sitting in a waiting room at Tesco - but HE wouldn’t be doing so :smiley: :unamused: :wink:
shep532:
Actually that’s exactly what he said, read the reply in conjunction with the question that was asked.
PhantomMajor:
i’m pretty sure that when i removed the digi card i did not set my status to rest.
chappy261:
If you still can’t see it try it this way
chappy261:
PhantomMajor:
Whether or not it was intended to read that way I’ve no idea, but that’s certainly the way it was written and it’s wrong.
shep532:
Those are the sort of courses/talks I like :smiley:
shep532:
dieseldave:
chappy261:
dieseldave:
Shep,
I quoted the whole of chappy 261’s first post on this topic, and it’s not a selective quote, so there’s nothing added or removed.
If you cannot see why chappy261 is incorrect, can you point to the part of the 561/2006 or GV 262-03 that I’ve missed?
shep532:
Agreed, but what “eventualities” could there be?
One certainty is that 561/2006 does not require a print out in the circumstances as stated by chappy261.
Another certainty is that VOSA’s own GV262-03 clearly stops short of making a print out to be an actual requirement in the same circumstances.
I’m at a loss to imagine what other “eventualities” there could be, unless those eventualities are foreseen by some other requirement, such as happens if any person fits any of the bullet points in my last post. :wink:
That’s my point about the importance of knowing exactly where the goalposts are, and the difference between that and good practice.
shep532:
I think this is true, so maybe chappy261 could tell us whether he meant it in that way.
shep532:
I complete agree with you here Shep, and that’s the very reason why I posted on this topic.
On the one hand we had the OP saying that he knew he needed to take a print-out, and on the other hand chappy261 saying that he must take two print-outs.
I’ll admit that at first I didn’t know who was correct, but surely you can agree that both cannot be correct in law.
I looked into it, and saw where the OP is correct. I also saw where IMHO chappy261 might have got confused.
I still think that chappy261 holds an honestly held, but mistaken belief.
shep532:
I also encounter this in a classroom, which IMHO is why I think it’s very important that the exact goalposts are properly known, as well as your point about being an ex-driver. Only then can an instructor do a good job of ‘chairing’ the ensuing discussion.
shep532:
I think I did exactly that, so I’ll stand by what I said in my post above on Mon Dec 24, 2012 at 5:12 pm
shep532:
The problem that sometimes raises its head is that sometimes (Eg. when company policy is given as ‘the law’) an OP can end up having to make a choice between well-meant, but conflicting pieces of advice.
:bulb: I also learned what the actual requirement is too. :smiley: :wink:
No matter which way chappy261’ meant to write his advice, I reckon the replies to the OP prove the need for clarity. :smiley:
ROG:
shep532:
The average DCPC course course content seems to lend itself very well to this way of going about training, but I completely agree with Shep’s words “well run,” because IMHO that’s the key to the experience being of real benefit to those taking part.
dieseldave:
No I can’t. I don’t think you have missed anything.
dieseldave:
So what does 561/2006 require in the circumstances as stated by chappy261?
shep532:
dieseldave:
dieseldave:
Shep,
I can’t see anything in 561/2006 to cover “any mistake you do…” etc as written by chappy261.
However, VOSA gives “strongly recommended” guidance just under the explanation of the tachograph mode symbols on page 38 of GV262-03.
dieseldave:
shep532:
dieseldave:
dieseldave:
Shep,
The paragraph you refer to says;
If for any reason the tachograph does not make an accurate record of activities (e.g. if the driver
inadvertently makes an incorrect manual entry in a digital tachograph, or fails to correctly operate the
mode button or switch), it is strongly recommended that the driver makes a manual tachograph record
to this effect. For digital equipment, the driver should make and sign a printout for the relevant period
with a note giving details of the error and reason at the time the error is made. For analogue equipment,
the record should be made at the back of the chart.
That seems to say what chappy261 wrote but VOSA have used better English. Granted it does not mention 2 print outs but aside from a waste of very expensive paper where is the problem. :wink:
The OP clearly felt the tachograph did not make an accurate record of activities or that he had failed to correctly operate the mode switch, chappy261 therefore recommended he make a written record to explain - it seems VOSA also recommend the same - indeed they do so strongly :wink:
All that I am getting at is that chappy261 was told he was incorrect when I don’t believe he was technically incorrect. My understanding of incorrect advice would be something like “You can drive for 5 hours without a break if you are within 30 minutes of base”. That would be incorrect. Or “You don’t need to bother with the WTD(RTD) because VOSA don’t enforce it” :smiley: :unamused: :wink: Or even “If all the DCPC trainers packed it in the Government would scrap the scheme” :laughing: :laughing: :open_mouth:
Unfortunately chappy261 used the word ‘must’ and I will begrudginlgy accept that this was not technically correct as it was not a ‘must’ situation, but as I have tried to explain previously, sometimes the word ‘must’ is often used out of context. Of course as someone quite rightly said it may be that chappy261 believed what he was saying was a MUST situation - in which case he was wrong :wink:
chappy261 did not however advise anything that would have caused an offence to be committed.
I think we have just about exhausted this topic … haven’t we? Unless chappy261 (or his Dad) would care to bring it back to life :laughing: :wink:
Have a great new Year :smiley:
shep532:
Agreed. :smiley:
shep532:
Again, agreed. :smiley:
shep532:
Agreed yet again. :smiley:
shep532:
This goes off the scale at the maximum end of incorrectness, so surely there’s nobody about who actually believes any of that. :open_mouth: :wink: :laughing: :grimacing: :grimacing:
shep532:
And the same to you and yours mate. :wink:
shep532:
I’ll say to you what I said to chappy261, I’m sorry but that’s nonsense.
According to what you’ve quoted VOSA recommend doing a printout if the tachograph for any reason does not make an accurate record of the drivers activities, I think we would all agree on that.
However that does not apply in this case because the OP did indeed make an accurate record of his activities and all he needed to do was a manual entry the next time he used a digital tachograph and yet he was told to do printouts.
In fact as you’ve pointed out yourself if he was using an old type digital tachograph he didn’t even need to do a manual entry, although I personally would always recommend doing a manual entry especially as it only takes a minute.
shep532:
You are yourself making a good case for the scrapping of the DCPC with the nonsense you’re posting in this thread :unamused:
To suggest that you need to do printouts if you leave the tachograph on other work when the card is ejected is incorrect, you can turn it round any way you like but it remains incorrect :unamused:
shep532:
So now you also think he was wrong :confused:
In the circumstances discussed in this thread not only was doing printouts not a “must”, it isn’t even a “should” nor even a “best to”, it’s simply not required, it really is that simple, and why was printouts not required ?, because although the OP being new to digital tachograph thought he may have done something wrong he hadn’t, therefore no printouts were necessary.
shep532:
No-one has suggested that the advise given would lead to an offence being committed only that it was incorrect
If someone asked me for directions from Birmingham to London and I told them to go north up the M6 then East on the M62 then south on the M1 to London, apparently you would say that was not incorrect directions because they would be doing nothing illegal by going that way :open_mouth:
Would it surprise you to learn that I would not expect someone to say “you could go that way but it’s not the best route”, I’d expect someone to tell me I was talking nonsense, which of cause I would be :unamused:
Likewise, to tell someone that they must, should, it’s best to, (insert your own phrase) do printouts for no reason at-all, whilst being legal is still the wrong advise, in fact it’s nonsense :unamused:
I have to say that if when you do DCPC courses you’re training people to do unnecessary and pointless printouts when they’ve done nothing wrong, it’s no wonder so many people question the validity of DCPC training.
tachograph:
It just goes to show I’m a much nicer chap than you then 'cos I’d use the "Well it’s probably not the best route, why not try this … " technique. :smiley:
tachograph:
I sell the print rolls at really good prices so it kindda makes sense … :grimacing: Most people leave the course with at least 10 boxes to be going on with.
shep532:
tachograph:
tachograph:
Fair enough, I take it you now realise you have no reasonable argument to back up the nonesense you’ve been posting so need to come out with that crap in order to hide the fact :unamused:
Perhaps in future you should stick to just trying to promote the DCPC at every opportunity and leave any other sort of discussion to people who can back up what they say with facts :wink:
By the way, if this was an attempt to get chappy261s father to put some training business your way, good luck :wink:
PhantomMajor:
Hi all,
yesterday was my first day in the real world doing multi-drop, because i was agency i was the last guy to leave with a run so there was no one around to help me with this type of digi tacho… see link http://www.digital-tachograph.com/files/0001/DTCOshortoperatinginstructions.pdf
so my question is this, when i go back, can i get a printout of my previous days work so i can detail the errors i made?
if i’m issued with a different vehicle that has yet another type of digi tacho, is it possible to do the same?
Hi there, I like to add to this debate. (I know my advice is a bit late but you can use it for guidance )
The bit in red is OK as in fact you have not finished you would sill have to hand in your keys and paper work, so if your in there next day do a manual entry for the time you pulled the card till you finished.
I only have change my mode to rest if I am tramping, and have finished for the day, if I do day or night work I never put it on rest at the end of my shift, because I have not actually finished work yet, there always some think to do like hand keys in or paperwork, or get my time sheet signed.
