Digi card runs out tonight, I’m on nights so when it ejects do I just put the new card in,or will I need to do any manual entry.
Can’t you just start your shift on the new card and not worry about swapping them over…I may be wrong but surely that would work??
If the wheels are turning when it passes midnight then the card will be spat out when you next stop if I remember correctly.
You can’t put the new one a day before as it’s technically invalid at that time
The card will eject anytime after 0100 as it is British summer time.
mine runs out in a couple of weeks, i do nights too…was wondering what would happen…
cheers
Leave the old card in, it will record to the end of your shift.
fingermissing:
THIS IS THE CORRECT ANSWER. op get pulled up at 00:59 hrs and await to be ejected at 01:00 hrs. New card in and crack on to Macon.
