Infringement
Fine
Failure to ensure recording equipment installed in accordance with Article 3(1) of the community regulation.
£200.00
Failure to ensure proper use of the recording equipment in accordance with Article 13 of the community regulation.
£120.00
Failure to ensure the correct functioning of recording equipment or driver card in accordance with Article 13 of the community regulation.
£60.00
Failure to ensure the proper use of the driver card in accordance with Article 13 of the community regulation.
£200.00
Failure to ensure that printing can be carried out correctly in the event of an inspection (other than failure to provide sufficient printing material), in accordance with Article 14(1) of the community regulation.
£120.00
Failure to ensure that printing can be carried out correctly in the event of an inspection by a failure to provide sufficient printing material, in accordance with Article 14(1) of the community regulation.
£60.00
Using a driver card of which the driver is not the holder, contrary to Article 14(4)(a) of the community regulation.
£200.00
Using a defective card, contrary to Article 14(4)(a) of the community regulation.
£60.00
Failure at the start of the journey, to print out information, etc, in accordance with Article 15(1)(a) of the community regulation.
£120.00
Failure at the end of the journey, to print out information, etc, in accordance with Article 15(1)(b) of the community regulation.
£120.00
Failure to use record sheets or driver card, in accordance with 15 (2) of the community regulation.
£200.00
Unauthorised withdrawal of record sheet or driver card, contrary to Article 15(2) of the community regulation.
£120.00
Failure to enter legibly on the record sheet, when away from the vehicle, periods of time, in accordance with Article 15(2) of the community regulation.
£120.00
Failure to amend record sheet or driver card as necessary when more than one driver on board the vehicle, in accordance with Article 15(2) of the community regulation.
£120.00
