i have a 2002/52 plate pre facelift model DAF 95XF with an ABS1 (truck) light on the dashboard
the mechanic i use plugged his diagnostic computer in to it, it showed that it was actaully an ASR fault, not an ABS fault
the wording on the display was “ASR Solenoid Valve Open Curcuit”
according to my local main dealer, the truck in question does not have ASR fitted ![]()
they advised me to look for a 4 pinned plug hanging down from somewhere above the midlift axle, this would be the plug that normally goes into the solenoid valve, after spending quite a lot of time looking for the plug with no joy, i decided to start checking the wiring looms for evidence of chaffing, with not much luck ![]()
the mechanic came back and pluged in again, it then said it was an ABS sensor fault on the front offside wheel, after 2 1/2 hours digging the old sensor out, cleaning the hole and refitting the new sensor, the light still did not go out
the mechanic came back to do a reset with the computer, the light came back on again, now saying that it was an ABS open curcuit fault on the front offside wheel again, traced that to a dodgy wire that plugs into the sensor
the plug and wire were replaced with a new section and wired in, all the wires from all the ABS sensors were checked for continuity from the sensor all the way to the ABS control unit, all showing good reading
the ABS light is still lit
the mechanic came back yesterday and did another reset on the memory, the light just comes straightback on again, this time, it is saying the same as the first time, ASR Solenoid Valve Open Curcuit
any help in solving this problem would be greatly appreciated, i have started pulling my hair out now (what bit i have left)
