Hi all, I found a problem sometimes when I drive Dafs with the manual gearbox.
Sometimes when trying to start the engine it won’t turn over as it thinks its in gear ? I move the gearlever around and try selecting different gears, range change splitter, nothing works and it still won’t start. Eventually I had been trying so long the air pressure had dropped below 5bar? and the red warning lights come on, then it started. Maybe being at low pressure it reset what was jamming it.
Seen this a few times, not usually so long to start though. Anyone else had this and know a quick way to fix it ?
( from a drivers point of view, not a owner/mechanic
