Help
Sent from my Lenovo A1010a20 using Tapatalk
Help
Turn the light switch to on?
22cwillc22:
HelpSent from my Lenovo A1010a20 using Tapatalk
Really need a hand as I have tried all the fuses and I got a load waiting to drop
Captain Caveman 76:
Clearly that was the first check I did
22cwillc22:
Captain Caveman 76:
Turn the light switch to on?Clearly that was the first check I did
Are the tail lights on the unit on?
Captain Caveman 76:
22cwillc22:
Captain Caveman 76:
No only have brake lights indicators and step lights
How old is the vehicle? Do you have the ignition (but not engine) on? If not, put it on and try again. When you turn the lights on and off, do you hear a little click from the relay? Were they working earlier?
Captain Caveman 76:
The answer to everything you asked is yes
22cwillc22:
Captain Caveman 76:
How old is the vehicle? Do you have the ignition (but not engine) on? If not, put it on and try again. When you turn the lights on and off, do you hear a little click from the relay? Were they working earlier?The answer to everything you asked is yes
It’s a 2013 daf xf105
Are your dashboard and tacho displays lit up? Backlight and information lights.
Captain Caveman 76:
No it’s but the TV and the kettle work
Ok, from memory (which has a nasty habit of letting me down), tail lights, headlights and auxiliary lights all have a common circuit but may use separate relays. The only thing I can think of as being common to them all is the light switch itself. IIRC them DAFs need the ignition on for them to work. Try running the engine, just to make sure, all I can think of after that is a dicky switch. You’ll need someone who knows more than me from this point on I’m afraid.
Apologies for the flippant first post I made.
22cwillc22:
Captain Caveman 76:
Are your dashboard and tacho displays lit up? Backlight and information lights.No it’s but the TV and the kettle work
The tacho display does and the computer display on dashboard does but nothing else on the dash does
Captain Caveman 76:
Ok, from memory (which has a nasty habit of letting me down), tail lights, headlights and auxiliary lights all have a common circuit but may use separate relays. The only thing I can think of as being common to them all is the light switch itself. IIRC them DAFs need the ignition on for them to work. Try running the engine, just to make sure, all I can think of after that is a dicky switch. You’ll need someone who knows more than me from this point on I’m afraid.Apologies for the flippant first post I made.
Thanks for the help m8[emoji6]
22cwillc22:
22cwillc22:
Captain Caveman 76:
Ok, so ignition is on but your light circuit is not. As above, I can’t help anymore I’m afraid. Hope you get sorted.
Cavey.
