Hi all i drive a daf cf 75 with air seat there is one switch that is puzzling me. It is a red one that illuminates when switched on but i have yet to find out what it does
Can anyone enlighten me please
Iv’e merged you two posts into one to keep the discussion all in one place. dd.
Does the seat get Warm when onâ– â– ?
stealthcol:
Hi i currently drive a daf cf whicn has an airseat. There is a a red switch on the seat when pressed illuminates. Does anyone know what this switch is for ?
prob heated seat
is it a little one on the right hand side of the seat to the front
It’s the heated seat button.
Ejector button, press it, you go out through the sunroof.
Its right hand side at back of all the other adjusters with a waterproof kind of clear gaiter over it i will try it in morning see if it gets warm while i do my walk around
tango boy:
not much help if the elements knackered
nick2008:
tango boy:
If it is knackered is it fixable ? If so is it an easy fix?
Is it an optional extra? The two CFs we have don’t have them, nor did any of the Dafs at Matthews Flour, yet I had a Foden Alpha which did have one (and worked a treat).
stealthcol:
nick2008:
tango boy:
It’s an easy fix insofar as it will just need the wire element soldering back together but, it’s less easy, as you will probably have to remove the seat cover material to find it. It varies how easy this is some you can have to unpick a load of wire hog rings with pliers.
Could be a fuse of course though
Press it and your arse gets hot
DAF95XF:
not if it aint working …Just because it lights up don’t mean squat
Rpg button,handy if tipping in Syria.
seth 70:
the optional extras are a milking stool
That’s only available on a 3 legger
