I’m going to fit a cb into a daf next week and the lorry had an aerial and power cable fitted by Daf when new but I can’t seem to find a mating plug for it any where, can any one help?
what model DAF is it?
in the XF95, the co-ax is located under the shelf in the centre cupboard, where the tacho head is, there is also a 12v supply tucked into the corner of the drivers side cupboard, the centre side
shuttlespanker:
what model DAF is it?in the XF95, the co-ax is located under the shelf in the centre cupboard, where the tacho head is, there is also a 12v supply tucked into the corner of the drivers side cupboard, the centre side
Its 56-plate CF. In the 2-dins above the driver you have the tacho and in the other one just a blank, I popped that out and power lead and aerial lead are in there. This is a photo of the plug.
