… and if replacing the roundy round thing, its a good idea to renew the oil pumpy pump thingy at the same time. ![]()
I want to know what he calls the valves. Inny - outies■■?
Driv3r:
Hi all,Been told today by a garage mechanic that the crankshaft has gone on one of our 26t trucks. Can anyone tell me what this means? I know nothing about engines!
Cheers!!
Must have been parked on the A14, they’ll nick anything there !
She does look rather fit. I hope they don’t have to wear that silly yellow jumper at the Olympics. ![]()
I have come over all Cosmo Smallpiece. ooerr
crank shaft
pistons pushing
sweating
uppy downy things
roundy roundy things
legs
lubrication
pumps
gardun:
Clicky-clackies?
She does look rather fit. I hope they don’t have to wear that silly yellow jumper at the Olympics.I have come over all Cosmo Smallpiece. ooerr
crank shaft
pistons pushing
sweating
uppy downy things
legs
lubrication
pumps
Whatever you do, don’t look at this
dunk1406.blogspot.co.uk/2009/05/ … n-fhm.html
BTW she can bench press 3x her body weight
Fit in every sense of the word
GasGas:
crank shaft
pistons pushing
sweating
uppy downy things
legs
lubrication
pumpsWhatever you do, don’t look at this
I am a little confused by the mention of The Three Peaks ![]()
I fitted a new crank in a 10 litre ■■■■■■■ that was in a Foden 4300 tractor, the part was 5 grand without any labour, gasket sets, shell bearings or anything els, that was 23 years ago.
Gembo:
You sure about that? You could have bought another truck for that money and certainly a recon engine. Not sure why you’d bother at that price + cost of the other bits + down time.
Driveroneuk:
Gembo:
I fitted a new crank in a 10 litre ■■■■■■■ that was in a Foden 4300 tractor, the part was 5 grand without any labour, gasket sets, shell bearings or anything els, that was 23 years ago.You sure about that? You could have bought another truck for that money and certainly a recon engine. Not sure why you’d bother at that price + cost of the other bits + down time.
Yep, that was from ■■■■■■■ UK in Slough back when I worked for BRS. Il never forget it to this day when I read the invoice.
The driver in question was travelling along the M4 and hit some stray road cones which knocked off the oil filter. Before he had time to get to the HS and switch off, it had spun half a dozern shells and totalled the engine.
I can understand that happening - but £5k just for a crank in 1989 ? Think sombebody seen BRS coming.
Driveroneuk:
BRS saw Courage’s comming ![]()
About 30 year ago i broke a crank in a 111 scania,fitter came out heard it knockin put his foot on the clutch and could feel it through the pedal .2000 pound for a new crank but my local garage got a secondhand one 150 pound .good days…
