hi all have my cpc mod 2 in 23rd may. few areas im struggling with. one being brake types and what each one means they are referred to a different name so could someone give explanation of each one eg
service brake
primary brake
emergency brake
secondary… etc
thanks a lot
Quality post MrFlibble!
Although I’d be a little tentative about the progressiveness of the secondary brake in most trucks I’ve driven so far…
It’s not something I really want to test!
Evil8Beezle:
Although I’d be a little tentative about the progressiveness of the second brake in most trucks I’ve driven so far…
Just as progressive as your foot brake, but you aren’t used to using it, so I would liken it to using the foot brake with your left foot… Usually results in a faceplant into the windscreen the first few times you try it
But with practice it can be gentle
I’m up for the windscreen licking, but it’s picking up the cargo that I’m not liking the thought of!
I’d assume it’s a bit like a biting point on a clutch, but you have complication from the muscle memory of that arm operating an On/Off brake switch… It’s going to end in tears, but I’ll give it a test if i’m empty and conditions are right!
nice on for the reply guys
