Correcting manual entries on tacho
Just a quick question I know you can correct manual entries on a tacho today I didn’t put my first break in so have an infringement. Can you add a missed break?
Quick answer: No.
Surprising to some of us but maybe not all lorry drivers are honest and upright, and if you could go back and add in breaks etc then there is the chance, some might go back and put in false info to avoid trouble!
do you mean you forgot to switch it to break when you stopped. or forgot to take one for wtd in the relevant time periods.
just do a couple of print outs and write on the back what happened. A once off isnt an issue in reality we all make mistakes. however if you did it alot then questions would quite rightly be asked.
The only manual entry you can correct on a digital tachograph is the manual entry you’re currently doing, once it’s accepted there’s no going back I’m afraid.
As said above, the occasional mistake isn’t going to get you hanged so learn from it and move on.
Thanks it’s WTD other work just forgot to add my first break wanted to get home too quick tonight
