Morning, has anyone done the above, XPO are advertising for an ADR PTO pump off class 2 driver in my area and was wondering what it entailed, it doesn’t mention tanks in the advert although all I can find on YouTube are tankers with PTO pump off! Cheers
In all liklihood it will be tanks. You can use a PTO to pump off from containers like drums or IBCs, but the room a PTO takes on a vehicle means it’s unlikely to be fitted to a non-tank vehicle on class 2, compared to a class 1 where it could be fitted to the cab and used as required.
Sent from my SM-G973F using Tapatalk
In case you don’t know what a PTO is, it’s basically an addition to the gearbox which draws power from the engine to drive a variety of ancillary equipment, all you need to do is have the engine running and push a button/turn a knob (on manual gearboxes you’ll need to dip the clutch first), and maybe set the cruise control to about 800rpm if that’s not automatic.
I know, drivers of newer vehicles may laugh at my description of having to dip the clutch, but we haven’t all had the luxury of up to date trucks ![]()
Zac_A:
In case you don’t know what a PTO is, it’s basically an addition to the gearbox which draws power from the engine to drive a variety of ancillary equipment, all you need to do is have the engine running and push a button/turn a knob (on manual gearboxes you’ll need to dip the clutch first), and maybe set the cruise control to about 800rpm if that’s not automatic.I know, drivers of newer vehicles may laugh at my description of having to dip the clutch, but we haven’t all had the luxury of up to date trucks
Yeah thanks, I know what a pto is, I used it alot when I left school and worked on a farm…
Heard back from them this morning, its a 28t carrying ibc’s to be pumped off, interview later today, then hopefully if goes ok start in the new year.
