10-08:
Yeah it was a Scania. I was hoping it was some kind of little gadget you wired in.
I’m sure you could get one but it ain’t gonna be cheap.
Its also wired to the central locking with 2 door lock modes that will only unlock the drivers door unless you press it twice which will then unlock both doors also has a full alarm and a ferry alarm which is a little less sensitive and used as it says on ferrys
Not ferry alarm but for when your in bed
Set alarm and it knocks off the internal sensors whilst you move around
But someone does your doorlock then the alarm goes off hopefully waking you up
Juddian:
MAN system doesn’t operate the reversing lights, but otherwise a useful tool.
yes it does
Not on the ones we used to have.
On an artic, it really doesn’t matter since there’s no legal requirement for reverse lights on a trailer, and even if fitted there’s no requirement for them to work - FACT
Juddian:
yes it does
Don’t see the need for reverse lights either. You can have reverse lights on, reverse beeper beeping and hazard lights flashing and some people still can’t figure out that you are reversing. :mad:
