I am looking at changing the stereo in my 64 plate DAF XF. How easy or hard a job is this? Is it just a case of unplug one and plug one in the new one?
Any advice gratefully received.
Thanks
Thanks
Not changed one in a DAF, but have done in a Volvo, as long at the unit is 12v shouldn’t be a problem and the Volvo had ISO connectors so only needed an adapter to wire the new JVC unit in, no cutting wires and crimping connectors etc.
madmackem:
I am looking at changing the stereo in my 64 plate DAF XF. How easy or hard a job is this? Is it just a case of unplug one and plug one in the new one?Any advice gratefully received.
Thanks
Like everything ,you may have to buy an adaptor loom,unless you know the plugs are the same …With some stereo units you may also need an adaptor for the ariel connection …If you pm me your chassis number ,I only need it from the G and the 6 numbers ,and i’ll have a look at the chassis diagram
Daf stereos are 24v
