I’ve been driving for a while now, using a digi card mainly and the odd analogue tacho, no problems with either, just the early days when I didn’t know what to do.
Below a small tale for the New & Wannabe’s to watch out for, it came as a surprise to me.
I started work at 05:00 approx. jumped in the lorry, completed the chart ready for work and inserted into the tacho machine and started paper work, walk round checks etc. I set off for my first tip, the day went to plan, until I stopped for a 45 break, I went to press the button to put the tacho on break and it was already on break, I thought that’s good, how did it know I was due to have a break; I pressed the button to check that all was well, no problem so left it on break.
After my 45 I carried on with my day, no dramas, back to the yard for 1630, checking the tacho once more, it’s back on break, taking the chart from the machine the whole day has been done on break! The machine is faulty was my first thought but when I checked the operation modes earlier all was well. At a loss as to what had happened I walked into the transport office to try and find out what was wrong.
The TM scanned my chart and said there was an obvious infringement, as if I didn’t know, and would have to sign the form indicating same, he went to explain what had happened.
There are some tacho’s which will not detect when the lorry is moving so not automatically switch to drive, nor will it sense that the lorry is stopped, therefore assuming other work, so in effect the last person to drive the lorry, which I had picked up, had left the tacho at rest, which was the correct mode for that person, I should have set the tacho to other work when I started work and then all would have been OK, but as I had assumed, obviously incorrectly, that it would switch to other work, drive etc I had inadvertently committed the error.
There are are only two lorries in the fleet, both registered in 2004, with tacho recorders which work in this manner, just my luck to get one of them!
Always check if you’re using an analogue tacho that the mode of operation is selected correctly before you do anything!
