Anybody have bother connecting a Samsung S5 to MAN TGX Bluetooth??
“MAN MT” shows up on bluetooth screen on phone ok but when I click it the phone turns off the bloody bluetooth then wait and it comes back on again but phone not paired.
No other devices on MAN or S5 Bluetooth as wiped them all to try to get it to work.
Phone connects perfect to Volvo FH4 Bluetooth hands-free and my Lexus and Wife’s Kia!!![emoji52]
Sent from my SM-J500FN using Tapatalk
Bluetooth isn’t a standard protocol Samsung is known for having issues I know they do the same thing with some Scania stereos
alix776:
Your right wouldn’t take on a works Scania the other week either!!![emoji52]
Its an Bluetooth comparability problem. Thank God I use a Lumia
My galaxy A3 pairs fine with the MAN TGX I drive.
I had similar issues when I tried to pair my Samsung phone (S6) with the Bluetooth in one of our MAN TGMs (pretty sure the same kit as used in the TGX). I somehow arrived at a point where the MAN MMT thing showed up on the phone but it wouldn’t pair. Yesterday I got it to work, by following this process:
Set the lorry up to pair with a new device (ignition on, stereo on, press Settings button then tap Bluetooth then Pair with New Device and you should get a screen telling you to start the pairing process from your device and to use the default 1234 PIN.
On the phone, tap Settings (or drag down from the top of the screen, tap cogwheel) then tap Bluetooth. Wait a minute until the word “Stop” in the top righthand corner changes to read “Scan”
On the phone, tap “Scan”
Enter the PIN when prompted.
If successful, the phone will then ask if you want to make the MAN a “trusted” device, and will also ask you to allow it to access your Contacts. Confirm both.
Roymondo:
Thx Roymondo,
Have done as you suggested and still the Bluetooth on the phone switches off when I hit pair “MAN MMT” when phone is in scan mode!!![emoji52]
There is always a “MTU4-640371” window appears below MAN MT with a “phone” symbol instead of the “hands free headset” symbol.
When you press this it DOES pair but nothing works via it if you follow??
Frigging pain in the arse when it works dead on with any FH4 Volvo!!!
Big Truck:
Bummer. I can’t suggest anything other than making sure your phone software is fully up to date. I have found a few similar (but not exactly the same) reports on other websites. Sadly no suggestions for a fix
Roymondo:
Big Truck:
Might just have to bring an older phone with me to work and change sim over! !!![emoji52]
Might be worth raising a support ticket with Samsung Tech Support? Won’t cost anything…
