thank you for flagging this as a source of confusion, indeed. Albeit, let us distance from the faggotry-laden taxonomy of āactiveā and āpassiveā.
The trailer is a long freacking thing, not the shorter two rear axles one steering to deliver Safeway stores in London, it is long and it contained 28 UK standard pallets one tonne each.
There is a button by the parking brake and shunting labelled āpress for shuntingā. So, there is no automatic device locking the rear axle, the driver has to come down out of the cab shine or rain and press it in order to lock the axle.
My uneducated approach when at a tight angle reversing is to leave it unlocked; once I am straight on the bay or at a mild angle, I come down and lock it for the final back-up avoiding Harry Pottering.
I did it locked all the time, and the cliunking and scrubbing the tarmac happened, so despite parking it up dead straigh I looked very Harry Potter at least to myself.
What I was asking by opening this thread, is for both the right textbook appoach and the expertise of those who deal with it on a regular basis.
Seriously mate, Iāve many years of experience behind me including many many shifts piloting a Terberg so my advice is ALWAYS lock the axle prior to reversing. I understand that you donāt want to scrub tyres, which is a fair point, but the simple truth is that if it isnāt the rear axle tyres getting r4ped it the middle or front ones. Can only be avoided by a relatively straight approach, but as we all know sometimes that just aināt possible.
The button by the park brake is nothing to do with the rear steer, it releases the brakes to shunt without hooking up the suzies. The rear axle should lock up when you are in a straight line and you engage reverse-it operates through the reversing light circuit. Hope this helps.
Iām confused?? I drive rear steer 40ft 33ft and 26ft trailers. No option to lock the rear wheels for reversing. We have 5 bays at angle for some of the 26ās but theyāre no issue given some of the places we have to reverse.
Or are you on about reve sing onto a bay which you canāt line up for? We got one of them too for a 40 ft and 33ft.
All the rear steer trailers i have come across ie 40 ft tandam P&O crap had self locking axles done through useing reverse gear, the problem was you had to be strait when it locked, (not easy at times) but by removing the revercing susie beforhand would lock the axle strait. ( ie no susie no rear steer)
As for the later 50+ ft i would not have a clue lol.
