For my work I could do with knowing the max drive and steer axle weights for a 44 artic and also the max allowable on STGO work.
TA
TA
the max drive axle weight is 10500 kg
it should tell you on the ticket
We dont have any ticket it is for a new road we have to build here
STGO 1 - up to 50 tonnes
STGO 2 - up to 80 tonnes
STGO 3 - up to 150 tonnes
Axle weights -
single non driving axle 10170kg
(figures from The Transport Manager’s and Operator’s Handbook - Author David Lowe)
Thanks for all the help this should satisfy the people at work
Our drive axle is plated at 11500 !!! the front steer and mid axle are both 7100.
jammymutt:
is that plated weight or design weight ?
Its plated waight Denis there is nothing in the design weight boxes.
According to a document I have from the FTA the maximum authorised weight of a drive axle is 11,500kgs, the 10,500kgs quoted above is the construction and use value.
a 40 ton 4x2 has a drive axle weight of 11500kg
a 44 ton 6x2 has a drive axle weight of 10500kg
a 44 ton 6x2 on steel suspension has a drive axle weight of 8500kg
hope this helps
paul
are you allowed steel at 44 tonne ?
the way i read it, yes you are, though the trailer has to be on air
cheers
paul
