UKtramp:
The last of the deep coal mines in Britain was Kellingley Colliery in Knottingley, Millions of £s worth of equipment was left underground as they destroyed the pit. There is also an estimated 25 years of coal reserves which could be brought to the surface still, yet they chose to close it down in order to bring in cheap imported coal from elsewhere. It is a financial decision which was made, people and their jobs do not enter this equation, whose problem is it to sort out the destruction of mining communities and re employ these workers? It is no different to the drivers of HGV in this country, no one cares if drivers lose their jobs. The drivers will have to simply find alternate employment in the same way the minors have to and equally in the same way when the fishing industry collapsed and fishermen had to find alternate employment. Autonomous vehicles will save billions of £s and have a positive effect on the economy
How do you explain the contradiction in rightly saying that the closure of the mines devastated the local economies where the miners spent their wages and added to the labour supply thereby depressing wage levels across the board.Then jumping to the opposite conclusion that putting the even higher number of those involved in driving everything from taxis to trucks on the dole will have a ‘positive effect’ on the economy in terms of lost spending and higher benefit burden ?.
Or how do reach the conclusion that many/most ‘drivers’ are not as solely dependent on their trade as miners were on theirs and that those skills are not actually even less transferable in many cases.While,even in the case of them finding ‘alternative’ employment,in an environment of even higher labour supply and in which automation increasingly takes over numerous alternative sectors, the wage levels will inevitably be lower.
Therefore the net result being less humans employed and those that are in an even more over supplied job market having earning less with less money to spend.With expensive robot technology turning out products or delivering goods which unemployed,or at best low paid humans,can’t afford to buy.
On that note,like Rjan,it seems clear that you’ve missed the point that we’re talking about a situation here which has the potential to tip the balance into the situation where automation removes more jobs from the economy than it creates.While also confirming that Rjan’s so called ‘state solutions’ will be anything but,in the form of saying a robot has taken your job now just get on with it. ![]()
