I don’t think you’ll have problems if you understand the basics that you put your foot on the clutch and move the stick thing then you’re halfway there, then it’s just understanding the layout of the box.
All this complaints about not training in a manual not getting a driver ready and it was better in my day when you used to have to train in a manual is ■■■■■■■■.
I trained in a ford cargo with a straight 6 box, pulling an empty 30ft flat bed trailer and for reversing I could see through the window in the back of the cab, it was a world away from the trucks I then drove on my first couple of years.
Volvo’s F cabs, 16 speed box 4 gears, range change and splitter giving 16 gears, towing a 45ft fully loaded tilt trailer. God my reversing was crap as I couldn’t see out the back window.
Foden with the infamous Eaton twin spliter 4 gears and 3 split positions for each gear giving 12 gears, oh and a constant mesh box to play tunes on.
pulling spud bulkers, a top heavy trailer when loaded.
Renaults 4 gears, range change, but unlike the Volvo switch, this one you push the gear lever across to change range, Called a slap over, and then a splitter, but not a switch but a rotating collar on the gear lever. Needed every one of those 16 gears to use the awesome 290bhp pulling 38tonnes.
Iveco Turbostar, 4 gears, range change and splitter, but only in high range, which is bloody confusing when you first drive it and forget and can’t get it back into low range.
Volvo FH, 3 gears, range change and splitter, not to difficult when you remember you haven’t got that 4th position.
However you then get a Scania, 3 gears, range change and splitter, so the same as the Volvo you say. No!
the third gear position is opposite to the Volvo, so if you’ve got out of a Volvo you spend the first few miles pulling the lever the wrong way.
Except they had a stick and clutch they bore no relationship to the straight 6 I learned on, but I, like many other, managed to master-ish all those. When I got a different truck I asked somebody or read the manual, (no Internet
in them days)
