We have had a new air tank and solenoid fitted to our 2008 Atego coach.
The seat no longer takes air. There are no leaking noises coming from the seat.
Can anybody suggest anything?
take it back to where they did the work…seems like they forgot to connect the air lines to the seat, should only be a minor problem…but very inconvenient.
I remember on an old
T reg Atego I used to drive, when you turned off the ignition, the seat would automatically dump the air out and rise when you turned it back on again. Not sure if your coach has the same set up. If it has, maybe the wire to the solenoid has been disturbed.
Well it turns out that the seat has a lever to lock it at its lowest level. This had been knocked during the service/inspection.
All good now. Thanks again.
