It’s one for mythbusters that’s for sure!
How do you get a 130ton lump inside a box with inches to spare, that’d need a fairly hefty fork lift, more to the point how did they get it out? Also from what I’ve seen, the equipment they were using out there in the 70s was one step away from a scrapyard, can’t see a flat or skelly being able to handle that weight, let alone the tyres. An axle with a 10ton rating could probably handle 20tons without too much trouble, any more than that & it would pulverize the bearings, bend the axle etc, the springs could probably take it too, the chassis wouldn’t bend if the load was, as said, spread evenly, but you’d need 5 axles on the trailer alone, at least three on the unit & some pretty beefy springs, on a standard 2800 & 40’ flat, I don’t think so somehow ![]()
I hear what you say about Roger, I don’t doubt you for one minute, you don’t work for somebody like Astran for such a long time by being a muppet, I understand his frustration (& laugh at his rants) BS demeans what you blokes have done, but I like to keep an open mind, like you say it’s a valuable learning tool & as you also say, it could be the years affecting memory & there could be an element of truth in the tales, it may turn out that the refractory bricks were hollow & then we’ve all got on our high horse for nothing ![]()
