Artego 815 brake light problem
Can anyone help… Both brake lights are on on my atrego when I have not got my feet on the brake or hand brake on. Looking by the brake pedal there appears to be 2 switches mounted next to each other and 4 loose cables, 2 labelled s4 and 2 labelled s85. I assume these have become detatched and need to be reconnected. Can someone confirm if it the 2x s4 terminals to either side of one switch and 2x s85 terminals to the other, or some other combination.
Thanks
Hello only reason I could think of for having 2 switches on the brake pedal would be one for the brake lights and one to knock out the cruise control.
Used to have old tractors (roadtrains) with a pair of switches but one was operated by a peg on the clutch pedal to operate the gearbox multiplate clutch brake in old twin splitter gearboxes.
Could it not be the brake light relay that has burnt the contacts and stuck closed?
The two pairs of wires might be one for the brake lights and one for the exhaust brake?
