anyone know ??
i do mine off the red airline to a 40’ hose, and tyre inflator. it’ll only get me to 90psi, but it’s enough to get me out of the [zb].
£30, and i got an air saw and grinder which brought it up to about £50. good for clamps. :slight_smile:
PSI doesn’t inflate tyres, you need CFM to do that.
It’s both really.
The volume of air in CFM that a compressor can put out drops as the pressure in the tank (or your tyre) increases. If you want to pump up wagon tyres there’s no point in having a compressor that can put out loads of CFM at 50psi if it drops off to near enough zero by the time you get over 100psi due to inefficient design. A decent compressor will include a chart that shows its output in CFM at various pressures from 0 up to 150psi and for pumping up tyres it’s the numbers at the top end of that range that matter the most.
Paul
Driveroneuk:
Bargain!!!
ebay.co.uk/itm/AIR-COMPRESSO … 2573338493
yeah looked at one of the other compressors this guy is selling same as in pic but 200ltr tank think it was £320 realy cheap for brand new one.
do anyone think they would be any good for what i want it for ■■? or a bit to cheap to be any good
john
limeyphil:
You should be able get more than 90 psi even without putting the cruise control on PTO.
busy fool:
Driveroneuk:
Bargain!!!
john
If you’ve got a couple of trucks and you want to inflate tyres swap wheels around and a few maintenance jobs then yes it’s a bargain even if it only lasted 2 or 3 years.
If you’re looking to run full time workshop operation or use in a service van then no. Although, having said that you could buy a second as a back-up also for less total price than the well known brands.
