Deesider:
Have a read through this post from a couple of years ago.It will give you a very good insight of what the job entails.
Although it features a different RDC, the job is by and large the same at all of them.
The subcontractor’s drivers tend to cover the same runs each day, whereas the main contractor, in this case DHL, will have their drivers covering a wider variety of stores in the region.
A driver that I work with at the moment used to work out of the LIDL Runcorn RDC has read through the post above and confirms all this.I can’t help with info on the current terms and conditions in your local region, you’ll have to get that from the ‘horses mouth’ when you get there!
Good Luck.
So you’re the reason this thread go resurrect from the grave.
