If you look a little harder next time you will notice that underneath the lorry sign it also says Caravans, in most MSA’s.
I don’t think they want to be parked in there either particularly when Jonny is ■■■■■■■ on his tyres and Borat is under his trailer ■■■■■■■■ in a carrier bag.
Same old s###, WHY must “drivers” run to the 4.5 time limit, whats wrong with stopping for a break or parking up at end off duty 10-15 minutes earlier,are they brain dead
I always tried to get a 15 in early on. Sometimes I would stop 20 minutes down the road, have a coffee and sort paperwork etc. By doing that, I only ‘needed’ a 30 in the middle, although I nearly always took more.
If one is not on a set run every day…15 MINUTES IS NOT LONG ENOUGH TO PLAN STOP…I start to plan when I have the address ,then after about three and half hours I am on the look out first toilets then with some luck a bit of piece .
